Date/Time: Sat, 31 Oct 2026 18:08:38 +0000
Transact to Denali Steps
View Count: 682
| [2022-03-25 13:40:26] |
| User577660 - Posts: 10 |
Hi, I have several questions on changing from Transact to Denali using a supported broker and the best steps to follow to not lose charts and chartbooks etc. I'm sure there is a link somewhere describing this. 1. How to change from Transact to Denali and the steps involved with changing to a supported broker? 2. Also, how then to update the symbols and not lose chartbooks, charts, studies, indicators etc. 3 And my last question is, should I copy the data out of the Sierracharts/transact data folder and put it in the regular data folder, and if so "when" in the process should I do all these things? Thank you |
| [2022-03-25 14:02:21] |
Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/TransAct.php#MigratingFromTransactToTetonOrderRoutingService Let us know if anything is not clear or you have further questions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
