Date/Time: Thu, 02 May 2024 10:47:03 +0000
Change Line Colors from Spreadsheet
View Count: 986
[2014-04-21 15:01:43] |
User025429 - Posts: 26 |
Hi I can create a line on a chart by using a spreadsheet study, using column O onward. Is there a way to change the color of the line from the same spreadsheet study? Thanks in advance. |
[2014-04-21 16:18:15] |
Yes to the first question. No to the second question.
