Date/Time: Fri, 16 Oct 2026 03:33:22 +0000
New chart setting
View Count: 782
[2022-03-22 17:04:06]
Juank - Posts: 2
Hello, how are you?
I have a problem finding the information about the new chart setting. all I see in the manual is the old chart setting with the different tabs; Main setting, Advance settings, Advance setting 2, etc... in the new one I am not able to find the old chart settings tab, it would not be a problem if I had the information to find what is inside these tabs (the old chart setting) in the new chart setting.
If you could please tell me where I can see this information, I would be very grateful.
Thanks,
Juan Carlos.
[2022-03-23 20:42:16]
John - SC Support - Posts: 48222
We are working on getting the documentation updated, but it will take us a bit as there is a lot to do. The main thing to remember is that if the setting is in the documentation, then it is on that window, somewhere (that is all Chart Settings that were there previously will be on the new Chart Settings window, somewhere). The organization of the new window is also much more intuitive than previously, so you should be able to figure out which tab a setting would be under based on the context of the setting.
Also, refer to the following for how to work with the new windows:
Settings Windows Interface
