Date/Time: Fri, 16 Oct 2026 03:37:00 +0000
Telephone and remote Assistance request
View Count: 868
| [2022-03-21 15:44:11] |
| User226793 - Posts: 175 |
Hi John, thank you for your help. I may need some help here. If you have 5 min, we can get on a quick call and I can pay for it. Here are some of my follow up questions 1. I am trying to use Nasdaq Total View for stocks and also the feed from TopStep Trader which is a rythemic feed. How can i run multiple data services on the same instance 2. Could I execute trades out of Sierra Charts for Stocks? Do you have any Direct Market access routes? 3. Can i setup alerts on multiple stocks, once the alert is triggered stock name is either shown to me or i have some voice translation? Date Time Of Last Edit: 2022-03-22 19:28:17
| [2022-03-22 23:37:58] |
Can someone help me with a quick phone consultation when I have to run multiple data feeds?
| [2022-03-23 21:12:38] |
| John - SC Support - Posts: 48222 |
1. Sierra Chart is setup to do this automatically. Whatever data you are not getting from us will come from your Trading Service. Just be aware of the following with regards to Rithmic data: Rithmic Trading Platform Service: Rithmic Support Policy 2. The only connection we have for trading stocks is Interactive Brokers. Refer to the information here: Interactive Brokers Trading Service 3. There is not a way to show you the chart directly, but you can get an Audio signal and you can make it anything you want. Refer to the information here: General Settings Window: Configuring Alert Number Instructions You can also have a pop-up window with the alert. Refer to the following: General Settings Window: Add Alert to Compact Alert Popup Window (Global Settings >> General Settings >> Alerts >> Additional Settings) ----- If you need help beyond this, then we recommend contacting Diana Pena at the following link: https://bio.link/dianapena For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
