Date/Time: Sun, 05 May 2024 14:17:59 +0000
Dukascopy data feed
View Count: 1586
[2014-04-21 14:12:02] |
User29310 - Posts: 1 |
Hello, I just got the détails from Dukascopy to connect their data feed to Sierra. I get the following message from Sierra : "error connecting to the data trade service" Server: demo-api.dukascopy.com or : 194.8.15.140 Sender Comp ID: DEMO1sPmXD_DEMOFIX TargetID: DUKASCOPYFIX Username / Password: your usual id I was phoning with them, they suggest me to ask to Sierra support. Please let me know what I should check / do. Thanks in advance. |
Private File |
[2014-04-21 17:04:39] |
We will be testing this to see what the problem is.
[2014-04-21 17:12:37] |
Please get from Dukascopy the port number to connect to. Apparently it is not the default port of 443. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
