Date/Time: Sat, 31 Oct 2026 18:08:21 +0000
Chart Settings Dialog Box is opening in a black spreadsheet modeless instead of windows?
View Count: 1252
| [2022-03-20 14:02:26] |
| bbsing - Posts: 3 |
I am trying to reset my chart settings dialog box back to the windows view versus the black spreadsheet modeless version. I have attached a picture of the current view. Please guide me, thanks
| [2022-03-20 14:36:10] |
| User907968 - Posts: 885 |
You can't, this is the new window type - Settings Windows Interface: Working with Sierra Chart Settings Windows |
| [2022-03-20 14:44:55] |
| bbsing - Posts: 3 |
Can I return to a previous software version? Some training video guides reference the other dialog boxes.
| [2022-03-20 15:00:00] |
You can. Help >> Install Previous Version.
| [2022-03-23 17:31:31] |
| John - SC Support - Posts: 48377 |
Also refer to the following information on how to interact with the new windows: Settings Windows Interface For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
