Date/Time: Mon, 20 May 2024 21:45:00 +0000
Number Bas and Number Bar Calculated Values new feature of Auto size font
View Count: 960
[2014-04-21 13:20:48] |
emp0804 - Posts: 31 |
Support, Can you add the same feature in the Number Bars and Number Bars Calculated Values as the new TPO feature of Auto Font size? |
[2014-04-21 18:44:16] |
We will see about this.
[2014-04-28 14:56:43] |
Al SC Developer - Posts: 434 |
In ver 1129, setting the font size input to zero, for the Numbers Bars and Numbers Bars Calculated Values studies, will auto size the font based on the available vertical space.
