Date/Time: Tue, 07 May 2024 00:52:38 +0000
No Username filled for CQG (Market Data) in "Data/Trade Service Settings" for Version 1123
View Count: 901
[2014-04-21 12:14:56] |
User18601 - Posts: 31 |
When you start SC with version 1123 and you use CQG, the username for the Market Data Connection Details is left blank. When you fill it, disconnect and connect again the connection to the server, it starts to work OK but when you exit SC and run it again, the field is blank again, you have to fill it up everytime you run SC.
[2014-04-21 16:00:32] |
This will be fixed.
