Date/Time: Tue, 07 May 2024 15:23:34 +0000
New Daily High/Low Alert Study Problems
View Count: 1001
[2014-04-21 12:09:13] |
cmet - Posts: 538 |
Is there any way to fix the following 2 things with this study?: 1. It fires multiple times in succession even though only a 1 tick new high/low alert is made. Is it possible to get it to fire once per bar and then reset? 2. This fires on market internals before the market is open. Using S&P Breadth, the session is set to U.S. market hours but the alert triggers before 9:30am. Can this be turned off? |
[2014-04-21 15:59:26] |
1. This should not happen. With the way the study is designed, if there is a new High only by 1 tick there would be one alert assuming you only have one instance of the study among the charts for the same symbol. Confirm that. Are you sure the daily High only increased by one tick during the time you heard the alerts. 2. No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-21 17:31:47] |
cmet - Posts: 538 |
I'm certain it was one tick. The tick at 64.50 this morning. 1 tick of the HOD for the full session. This happens on all symbols. In this case: ES, SP Breadth, NYSE Tick. |
[2014-04-22 07:56:22] |
We are going to be updating the study function and add more descriptive text to the Alert Message in the Alerts Log to determine the source of the problem. This will be out in the next release.
