Date/Time: Sat, 31 Oct 2026 18:47:02 +0000
Horizontal lines automatic transfer to new contract
View Count: 724
[2022-03-17 14:01:24]
User58008 - Posts: 32
I would like to ask - is there a way for my horizontal lines to automatically "transfer" to new contract period (e.g. from H22 to M22 on NQ100 chart)? I thought this will be solved by Continuous futures contract, but when my chart changed to NQM22, the lines did not transfer and the chart is "blank".
Is there any way how to do this without manual transfer for each line?
[2022-03-17 14:56:07]
We assume these are drawings, therefore you would want to "rollover" the drawings at the same time as you do the symbol. When you rollover the symbol you get a window which has an option for Also Rollover Chart Drawing Symbols on it. Be sure to select that option when you perform the rollover.
If you forget to do so, you can then select Chart >> Update Chart Drawings to Current Symbol to update the drawings for the active chart. Refer to the information here:
Chart Menu: Update Chart Drawings to Current Symbol (Chart menu)
