Date/Time: Sat, 31 Oct 2026 18:47:09 +0000
Ask volume bid volume difference text
View Count: 884
[2022-03-17 08:28:30]
Calinorth86 - Posts: 15
Is it possible to changer the format of the text. I want to eliminate the .00, all I need is whole numbers. So for example from 100.00 to 100
[2022-03-17 11:15:54]
User907968 - Posts: 885
Yes, change the Value Format in the study settings window to 1.
Chart Studies: Settings and Inputs Tab >> Value Format
[2022-03-17 17:16:44]
This all I see in the study settings window.
imageScreenshot 2022-03-17 101301.png / V - Attached On 2022-03-17 17:15:35 UTC - Size: 68.16 KB - 315 views
[2022-03-17 17:43:22]
Change the Value Format on the left side from "Inherited" to "1". Refer to the following:
[2022-03-17 18:42:33]
Got it thank you for your patience im quite new at Sierra Charts, and trading in general.
