Date/Time: Mon, 06 May 2024 22:04:27 +0000
DOMAccess() function
View Count: 976
[2014-04-20 15:07:41] |
User44130 - Posts: 23 |
Hi, I'm trying to handle depth of market data using coding method describbed in DOMAccess() example function. However, it works only when Market Depth window is open and connection to this service is established. If the Market Depth window is closed, DOM data from code is not available. 1) Please advise how to get DOM data in program without opening DOM window. 2) Is it possible to handle DOM data in program for multiple symbols? Thanks |
[2014-04-20 21:46:21] |
1. Set sc.UsesMarketDepthData = 1; 2. Do you mean within a particular instance of a study function? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
