Date/Time: Sat, 31 Oct 2026 18:47:00 +0000
Data Package
View Count: 842
| [2022-03-14 15:26:38] |
| User469888 - Posts: 5 |
Hi there, I can't seem to find the Russian Ruble futures among the available instruments. Do I need to upgrade something to access that symbol?
| [2022-03-17 22:42:10] |
We have added this but only for the Teton Order Routing Service which replaces the older Sierra Chart Order Routing Service: Sierra Chart Teton Futures Order Routing You need to ask your broker to move you to Teton. Also refer to: Important Notice for users of Sierra Chart Order Routing Service. Not referring to Teton. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-17 22:42:56
