Date/Time: Mon, 29 Apr 2024 12:49:50 +0000
[User Discussion] - Excel
View Count: 1264
[2014-04-18 16:37:17] |
User78745 - Posts: 38 |
Dear, Could we add a study as Numbers Bars Calculated Values on Excel ? Could we watch them on Excel ? There is any way to do it ? Regards, |
[2014-04-18 23:51:48] |
We do not provide help with Excel. You can try using Excel with the Spreadsheet Study but we do not provide any technical help with that.
[2014-04-19 00:06:40] |
Sawtooth - Posts: 3983 |
Add the Spreadsheet Study study and you'll see the Numbers Bars Calculated Values outputs in columns AA and above. If you set Use Excel to Yes, it outputs to Excel, but you can do most things within Sierra's spreadsheets and spreadsheet studies. |
[2014-04-19 09:12:00] |
Tx you Tomgilb, As you said at the end of your thread, you can do most things within Sierra's Spreadsheets. This is what I need. Have the NB calculated on a Spreadsheet within Sierra. I want to follow them in real time. Regards, |
