Date/Time: Mon, 19 Oct 2026 02:59:01 +0000
Not finding Activate Trial section
View Count: 781
| [2022-03-07 18:25:56] |
| User505884 - Posts: 11 |
Hi, according to the documentation here (Sierra Chart Trial Account) I need to go to Global Settings >> Activate Trial to start the free trial activation process. However, the Activate trial option is not under global settings. Has it moved?
| [2022-03-07 18:35:47] |
| Sierra_Chart Engineering - Posts: 25213 |
We went ahead and activated your Sierra Chart account. The problem is you are running an older version. You need to update. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-07 18:36:27
