Date/Time: Mon, 29 Apr 2024 17:42:44 +0000
Remote Data - NET & non-NET
View Count: 1684
[2013-04-25 15:18:42] |
TastyRisk - Posts: 119 |
Support; I have CTS data. Of course the install must be .NET so it's limited to 1.8GB RAM size. If I set-up a non-.NET install to read the CTS data files, will the non-NET install be able to use the full 3GB of RAM? ...or will there be some cross-linking resulting in a 1.8GB memory limitation ? In any case: is mixing .NET & non-.NET installs and then sharing data generally advisable ? Thanks for your help. Date Time Of Last Edit: 2013-04-25 15:19:18
[2013-04-25 17:09:09] |
We do not know the answer to the first question. It is fine to use both the CLR and non-CLR version. They can easily share data between each other. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
