Date/Time: Mon, 12 Oct 2026 02:52:20 +0000
Interactive Brokers does not respond to orders made on sierra chart
View Count: 1070
| [2022-03-04 15:24:42] |
| fordman90 - Posts: 4 |
When i enter orders on Sierra chart, the orders do not respond on IBKR. They do not appear at all on IBKR. Is there a simple setting or something that I may be missing somewhere? After going through the setup documentation multiple times and looking through the support boards, I have not been able to find a solution. Has anyone else had this problem? If so how did you fix it? Thanks |
| [2022-03-04 15:42:18] |
| Tony - Posts: 725 |
I had similar problem quite a while ago, the very first order of day I sent from a chart window didn't appear on TWS window, but from second order and forward, it seemed fine. I assumed that was caused by IB's API and there were nothing Sierra could do, so I just place orders in TWS window, and didn't bother to check if the issue is still there for the new Sierra versions, I don't want take any chances. |
| [2022-03-04 16:20:33] |
Most likely the problem is you have Trade >> Trade Simulation Mode On enabled. Disable that. Regarding post #2, we have never heard of a problem like that before with TWS. You should test again. We would not expect you would have that problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-04 16:21:07
| [2022-03-04 16:26:39] |
YES! It was as simple as turning off trade simulation. Thank you for your quick response!
