Date/Time: Mon, 12 Oct 2026 02:49:56 +0000
Quarters Theory
View Count: 1349
| [2022-03-04 02:14:13] |
| Matador Trader - Posts: 24 |
Good Day Good People! I use my take on Quarters Theory and was wondering if there was any way to automatically have the session high/low divided into quarters lines?? Currently I use the price retracement tool and change the fib values to 0,25,50,75,100 which works fine - just every time a new high or low is printed I have to delete the drawing and redraw. Thanks in advance for any advice or tips! Good trading always! |
| [2022-03-04 15:29:19] |
| John - SC Support - Posts: 48169 |
Start with the High/Low for Time Period - Extended study which will give you your High and Low for the period you want. Refer to the following for more information: High/Low for Time Period - Extended Then you can use either a combination of the Arithmetic Studies or the Spreadsheet Formula study to produce the lines in between the High and Low. Refer to the information at the following link for the Arithmetic Studies: Using the Basic Arithmetic Studies And refer to the following for the Spreadsheet Formula study: Spreadsheet Formula For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
