Date/Time: Mon, 12 Oct 2026 02:53:36 +0000
saving depth dat but not actual depth
View Count: 877
| [2022-03-03 19:58:47] |
| User61576 - Posts: 458 |
is there any way to dave the depth ratio the same it updates on my chart using the study subgraph difference if i use 10 seconds candles, how can i update every change on the difference and to store it? i don't want to store the depth itself thanks |
| [2022-03-03 21:36:54] |
| John - SC Support - Posts: 48169 |
We are not sure what you are using to get the Depth Ratio, but if you are getting what you want from a study, then you can use one of the export options available to save out that data. Refer to the information here for exporting the data: Edit Menu: Edit >> Export Bar and Study Data to Text File And also refer to the information for the following study that saves the data as it is developed: Write Bar and Study Data To File For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-03-04 11:27:36] |
ok thanks and if i do want to save depth data? |
| [2022-03-04 16:09:51] |
Refer to the following for saving Market Depth Data (the section is about saving Market Depth for replay, but regardless of why you want it, the instructions are the same): Replaying Charts: Replaying of Market Depth Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
