Date/Time: Sat, 12 Jul 2025 00:59:29 +0000
[User Discussion] - Copy trading
View Count: 3500
[2022-03-03 17:21:08]
g4500 - Posts: 27
Hi
I would like to copy my trades from one account to the other.
One is under AMP and the other is under edgeclear.
Both account would be traded under the same computer.
Can you recommend me how to proceed if it s do able of course
[2022-03-03 17:48:56]
John - SC Support - Posts: 40857
There is no native support for doing this between accounts at different brokerages like this within Sierra Chart.
Date Time Of Last Edit: 2022-03-03 17:49:22
[2022-03-03 18:31:26]
g4500 - Posts: 27
Thank s for the answer.
Do you know or recommend an external company who provide this services or study?
[2022-03-04 15:41:07]
ForgivingComputers.com - Posts: 1077
I have a study that does this plus it also converts from futures to Long Equities for echoing to retirement accounts. Contact me by email or Direct Message.
Brad (at) forgivingcomputers (dot) com
[2022-03-06 08:49:24]
Ticks - Posts: 206
@bradh
Are you saying that your study can copy trades between separate accounts at different brokerages?
ie: trade in sim mode in SC and copy those sim trades to 4 eval accounts at one prop firm and also to 5 eval accounts at a different prop firm.
Date Time Of Last Edit: 2022-03-06 08:50:41
[2022-03-06 13:02:40]
Yes, with limitations. It copies trades within and between instances. If a broker supports multiple accounts per instance (similar to Sim1, Sim2, etc.) then one Sierra instance is required per broker. So assuming that is the case with the prop firms, then one instance is used for sim trading, one for prop firm A, and one for prop firm B. If the prop firms allow only one account per instance then a total of 10 instances would need to be running at the same time.
There may be other possibilities with the Order Routing Service, but those have not been tested.
[2022-03-06 19:18:47]
Ticks - Posts: 206
@bradh sounds good so far.
Well, here is the super important part.
When/if the stops and targets (attached orders trailing stop etc)or manually, are adjusted during the trade on the master account, will the stops and targets also adjust on the other slave accounts?
Because having to manually adjust the stops or targets on each 9 separate accounts would be an account destroying nightmare to manage.
Date Time Of Last Edit: 2022-03-06 19:46:36
[2022-03-06 21:12:23]
Yes!
[2022-03-06 21:31:07]
Ticks - Posts: 206
@bradh request sent for DM permissions.
[2022-11-04 12:46:54]
Anton Bednár - Posts: 2
Hello @Bradh, would it be possible to get more info and study which could copy trades?
Thanks a lot.
[2022-11-04 19:25:05]
I hope to have a public beta available before year-end.
brad (at) forgivingcomputers (dot) com
[2023-01-21 15:13:36]
User636370 - Posts: 24
found this thread and wanted to know if you released a public version.
i'm interested in running multiple SC instances on VPS for trading across brokerage accounts.
thanks for the effort on this!
[2023-01-21 15:20:28]
No public version yet. Need to wrap up another project first.
[2023-01-21 21:03:55]
User701453 - Posts: 176
@ User636370
This developer has a trade copier.
Date Time Of Last Edit: 2023-01-21 21:04:45
[2023-01-21 21:24:31]
jeden8l - Posts: 48
aimfx.io
Lukas has been developing this for years already. First tool on the market. Very recommended
