Date/Time: Mon, 12 Oct 2026 02:50:18 +0000
Switch over to Sierra
View Count: 856
| [2022-03-03 15:40:57] |
| User676981 - Posts: 2 |
Hello, i curently have a AMP Futures account and would like to switch over to your platform could you direct me in the direction to start using using the software. i already downloaded and want to set up data and merge it with AMP |
| [2022-03-03 16:46:50] |
| John - SC Support - Posts: 48169 |
Make sure you have gone through the Getting Started information to learn how to use the basics of Sierra Chart. In particular go through the following set of instructions for opening a chart: Getting Started, Opening Charts and Basic Trading: Open A Chart Is your AMP account setup to use CQG or Rithmic for your order routing? Also, what are the exchanges for which you want real-time data? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-03-04 02:40:31] |
So I paid for Denali 11 but still have delayed data. How is it that I get real time? Do I need to connect to AMP? And if so how do I do that?
| [2022-03-04 15:30:51] |
