Date/Time: Sun, 05 May 2024 15:45:29 +0000
alphablend in log keeps log open with error message every second or so
View Count: 836
[2014-04-17 14:06:33] |
User33552 - Posts: 23 |
This stays on my screen continually...how do I get it off and how to fixx this error message?
log.doc - Attached On 2014-04-17 14:04:18 UTC - Size: 65.5 KB - 338 views |
[2014-04-17 16:51:04] |
This is an operating system problem. The usual solution to it, is to restart your computer. If this is an ongoing problem and you are using transparency with any of the studies or tool drawings, we recommend not using transparency. For tool drawings, the Fill Transparency for the drawing tool should be set to 0% or 100%. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
