Date/Time: Mon, 29 Apr 2024 00:44:34 +0000
Spreads with CQG FIX Trading
View Count: 1204
[2014-04-17 08:40:04] |
VF56002 - Posts: 27 |
Hello, my account has been transferred from ILQ (TT FIX) to Advantage Futures (CQG FIX). In Find Symbol window there was a button "Get spread symbols" with TT but this button is missing with CQG. Can you advice how I can get spread trading DOM for any combination open? Thanks Date Time Of Last Edit: 2014-04-17 08:41:00
[2014-04-17 08:51:35] |
We have to look into this.
[2014-04-18 09:34:57] |
any news for spreads with cqg? thanks
[2014-04-18 10:26:52] |
This is capability that has to be developed. It will take time to implement. We do not expect to get to this for about a couple of weeks at least.
[2014-04-18 17:12:04] |
If I get it right I can't even use contract name to open DOM? Like: F.US.ZCEK14 - F.US.ZCEN14
I suppose CQG support spread contracts ...So if I want to exit my transferred positions I need to do it using outrights leg by leg? Thanks Date Time Of Last Edit: 2014-04-18 17:12:40
[2014-04-18 21:29:56] |
If that is a valid CQG symbol, it will work. You would need to exit the position leg by leg. Or call your brokers order desk. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
