Date/Time: Mon, 29 Apr 2024 00:26:29 +0000
Numbers bar question
View Count: 926
[2014-04-17 06:04:59] |
User56254 - Posts: 6 |
Hello, I don't understand in your documentation (Numbers bar) how you calculate "Max AskVol-BidVol". I send you a screenshot to you to take an exemple to explain me. http://www.sierrachart.com/image.php?l=1397645805651.png Thank you in advance. |
[2014-04-17 08:07:32] |
This is documented in this section here: http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#SubgraphDescriptions We reviewed the documentation and we made it is clear as we could. Could you please look at it again. For the definition of Ask Volume and Bid Volume , refer to: http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#AskVolume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-17 08:08:16
