Date/Time: Sat, 31 Oct 2026 20:12:59 +0000
[Programming Help] - ASCIL - excluding Saturday, Sunday and/or weekend data
View Count: 1634
[2022-03-01 10:26:57]
User92573 - Posts: 622
Dear Support
Is there a simple way "function" that will allow me to exclude weekend data from a study such as in the Daily OHLC study which offers:
a) Exclude Saturday data
b) Exclude Sunday data
I note that several years ago a thread said this was being considered.
Ideally something like the "Daily OHLC" Study but with the addition of a Start time and End Time for intraday.
Many thanks.
Date Time Of Last Edit: 2022-03-01 10:47:08
[2022-03-01 11:49:08]
1+1=10 - Posts: 270
Yes, use SCDateTime::GetDayOfWeek
Working with the SCDateTime Variables and Values: GetDayOfWeek()
You probably need something like what is below:
if(sc.BaseDateTimeIn[sc.Index].GetDayOfWeek() == SATURDAY ||
sc.BaseDateTimeIn[sc.Index].GetDayOfWeek() == SUNDAY )
return; // Don’t process any weekend bars
Date Time Of Last Edit: 2022-03-01 11:49:50
[2022-03-01 15:41:04]
Hi, thank you for the reply.
That's what I'm using in my Auto-loop code but for some reason I just cannot seem to get it to work in the same way in the Manual-loop version.
Clearly it's me, as IsSaturday, IsSunday and the above otherwise works fine.
Thank you for the assistance, I'll have to explore manual looping further.
[2022-03-01 15:57:37]
It just a study to show the High/Low for the current selected timeframe using a start-time, end-time and an option to exclude weekend data.
I've used the "HighLowForTimePeriod" study as a template so should be very straightforward but for some reason I'm struggling with the Weekend section even though my Autoloop test using "if(sc.BaseDateTimeIn[sc.Index].GetDayOfWeek() == SATURDAY ||
sc.BaseDateTimeIn[sc.Index].GetDayOfWeek() == SUNDAY)" works fine.
[2022-03-01 16:38:47]
1+1=10 - Posts: 270
HighLowForTimePeriod implements manual looping using the for-loop below. Inside that for-loop you need to put the if statement, along with the other relevant code; you likely need:
NOTE: "Index" in below for loop refers to the bar index being processed by your code. In automatic looping a different bar, referred to by sc.Index is processed for every call of your study. In manual looping on the other hand you need a loop such as below and you can process as many bars as you want for each call of your study. Yes, check out the docs: Working with ACSIL Arrays and Understanding Looping: Manual Looping/Iterating
for (int Index = sc.UpdateStartIndex; Index < sc.ArraySize; Index++)
// Other code
if (YourInputToControlExcludingWeekendData.GetYesNo())
if(sc.BaseDateTimeIn[Index].GetDayOfWeek() == SATURDAY ||
sc.BaseDateTimeIn[Index].GetDayOfWeek() == SUNDAY )
continue;
// Other code
Date Time Of Last Edit: 2022-03-01 16:39:48
[2022-03-01 18:04:41]
Thank you I'll sit down with it again tomorrow and see if I can solve it. That's very helpful.
Many thanks
[2022-03-01 18:25:26]
1+1=10 - Posts: 270
Good luck!
