Date/Time: Thu, 02 May 2024 00:42:20 +0000
Trade Window Configuration Selection
View Count: 875
[2022-02-27 18:06:45] |
@TRADE_YOUR_PLAN - Posts: 126 |
I use Control Bars to select order quantity and saved Trade Window Configurations for saved order configurations. When selecting quantities using these Control Bar buttons, the quantity buttons highlight if selected as usual. However, when I select a Trade Window Configuration, the Control Bar button does NOT highlight. Without having an attached Trade Window (which is a space waster for me), I have no way of confirming a Trade Window Configuration prior to order placement. Shading of this seems to be an oversight. See attached picture if you need clarification beyond the preceding text. Thanks |
Trade Window Configuration is not highlighted on selection.png / V - Attached On 2022-02-27 18:05:15 UTC - Size: 43.98 KB - 219 views |
[2022-02-27 23:59:38] |
We will add support for this in the next release.
[2022-03-01 04:05:19] |
The update works beautifully- thank you. For those of you wanting to customize your trade window, this is a wonderful alternative considering multiple control bars can be used and attached to trade DOMs that are detached from chartbook spaces. See attached for example.
Control Bar as Trade Window.png / V - Attached On 2022-03-01 04:05:13 UTC - Size: 11.31 KB - 264 views |
[2023-05-23 17:19:23] |
User176810 - Posts: 2 |
Can you help me please set up the trade window exactly as you have it in th eattached file? |
[2023-05-23 21:35:32] |
John - SC Support - Posts: 31293 |
That is not a Trade DOM, it is a Control Bar that has the various items added to it. Refer to the following: Control Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
