Date/Time: Fri, 03 May 2024 17:43:00 +0000
Problem with Overlay(Bar) study
View Count: 933
[2014-04-16 18:57:45] |
buylosellhi - Posts: 60 |
Hi, I'm trying to overlay a 240min chart onto a 60min chart. But when I insert the Overlay(Bar) study in the 60min chart and then select the 240min chart to overlay, it forces the 240min chart to become a 60min chart and then overlays that on the 60min chart - basically redrawing on top of the 60min chart. Has anyone else experienced this ? thx in advance for your help |
[2014-04-17 00:51:51] |
The study for this kind of purpose you need to use is the Study/Price Overlay Study: Http://www.sierrachart.com/index.php?l=doc/helpdetails28.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
