Date/Time: Thu, 02 May 2024 02:47:30 +0000
Ho w to make Senkou Span (Ichimoku) color transparent ?
View Count: 2122
[2013-04-25 14:16:18] |
bwasi - Posts: 34 |
and therefore can see through candlesticks behind it in chart ?
[2013-04-25 16:42:56] |
Sierra Chart - Max - Posts: 5598 |
On the Study Settings >> Subgraphs Tab set the Draw Styles to Trans. Fill Top and Trans. Fill Bottom. To modify study settings, please see: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#AddingStudiestoaChart Sierra Chart Support |
[2013-04-25 17:32:29] |
In the Study Settings window for the study, you can also enable Draw Study Underneath Main Price Graph.
