Date/Time: Fri, 03 May 2024 03:49:24 +0000
How to cancel bracket order
View Count: 941
[2014-04-16 18:55:07] |
stab654 - Posts: 1 |
Hello, I bought 1 ES at the market with a attached bracket order, then I bought another ES at the market w/bracket order. I sold 1 ES unattached, and the bracket orders for the 2 longs are still showing instead of just 1 bracket order for the existing long position. Please advise if there is a way to cancel 1 of the attached brackets when 1 of my positions were offset. Regards |
[2014-04-17 00:49:51] |
If you currently have this position, you need to manually adjust the quantity of those Attached Orders to 1. Here is the documentation for that: http://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#ModifyingOrdersOnTheChart Next time we recommend using the Scale Out functionality: http://www.sierrachart.com/index.php?l=doc/doc_AttachedOrders.html#ScalingOut Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
