Date/Time: Sun, 19 May 2024 12:02:35 +0000
Trade Activity Log - No Runup/Drawdown Stats
View Count: 1239
[2014-04-16 17:50:24] |
Futures Operator - Posts: 239 |
In v1120 on TT FIX, there are no runup/drawdown stats in the Trade Activity Log for Non Simulated trades. Looking at the Order fill data in the Trade Activity tab, there is no High/Low/Last during position data recorded, these fields show blank. Can we get this functionality restored?
[2014-04-16 17:59:52] |
No. It does function correctly, but that data is not always going to be available if you are not connected to the data feed during the full-time of the position. Refer to the documentation for those fields. Actually, we know what you are referring to now. Because you are using Trade >> Use Fill Calculated Positions-Global, the high and low data will not be maintained because it cannot be accurate. Please do not ask us anything more about this. It is just not going to work when using that option. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-16 18:36:46] |
In previous versions that data was working with order fill calculated positions, and only needed to be corrected rarely, which was not so bad, where now it would need to be completely manually inputted to see this data. I agree, these issues are time consuming and should not be this difficult. Is TT a bad match for Sierrachart? Can you suggest a better matched alternative trade service to avoid position reporting/data during positions, and any/all other issues in Sierrachart that is the most robust and always works reliably? |
[2014-04-16 21:53:03] |
Really any other service would be fine. From what we understand using TT FIX through AMP clearing, overnight positions are reported. Through AMP it is called TT Net, but it is the same as TT FIX. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-17 05:46:47] |
Also all non simulated trades placed in v1120 show unmatched fills in Trade Activity Log due to only showing Open in the OpenClose field, though there are matching sells for every buy. Thus there is no exit price. PnL, or Trade Statistics for any of the trades. I presume this is not the expected behavior, even with Fill Calculated Positions-Global on? Date Time Of Last Edit: 2014-04-17 06:41:42
[2014-04-17 06:10:31] |
If you had to pick the service that is the most reliable/best integrated with SC/has the least issues, what would it be?
Date Time Of Last Edit: 2014-04-17 06:18:16
[2014-04-21 16:55:56] |
Also all non simulated trades placed in v1120 show unmatched fills in Trade Activity Log due to only showing Open in the OpenClose field, though there are matching sells for every buy. Thus there is no exit price. PnL, or Trade Statistics for any of the trades. I presume this is not the expected behavior, even with Fill Calculated Positions-Global on? We tested this we do not see the problem when using Use Fill Calculated Positions-Global. After enabling that option, select Edit >> Refresh Log on the Trade Activity Log. That is an essential step. We do like TT FIX. But the only choice for that right now is AMP due to other clearing firm's dropping support for it and 10 minute delayed historical data. With AMP the historical data will not be delayed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-22 19:09:02] |
Fixed after the refresh step. Is there any way to confirm if overnight reporting works correctly with AMP's TT FIX adapter? They said they are confirming with you. Date Time Of Last Edit: 2014-04-22 19:09:34
[2014-05-01 02:49:28] |
v1129 supports overnight with Amp/TTNet. Could you update the documentation with the details of how this is handled now? https://www.sierrachart.com/index.php?l=doc/AMPTTNet.php#OvernightTradePositions Does it work natively on the FIX adapter, without Use Fill Calculated Positions, and support high/low during position data? Could this type of implementation for overnight positions on TT work through Advantage Futures also? |
[2014-05-01 07:16:29] |
The documentation for Overnight Trade Positions on the AMP TTNet page has been removed. It is no longer relevant. Does it work natively on the FIX adapter, without Use Fill Calculated Positions, and support high/low during position data?
Yes.Could this type of implementation for overnight positions on TT work through Advantage Futures also? Possibly. We would have to add an option for it and you would have to experiment with it.
[2014-05-01 08:44:21] |
I do not have an account with Advantage so can not experiment with it, but if you could add it, we would have another option for TT and overnight, and may be willing to switch to it then, as many other users may be.
Date Time Of Last Edit: 2014-05-01 08:44:52
