Date/Time: Sat, 04 May 2024 05:46:02 +0000
Big spikes intraday
View Count: 919
[2014-04-16 17:41:20] |
M5amhan - Posts: 468 |
Hi, On my intraday charts, sometimes a huge spike is printed but it doesn't really happen. When I delete and download the data it goes away. It's not a big deal really and it's something that has happened since I started using SC again but if there is something I can do to prevent it from happening that would be great. Here is an example from this morning: Before - http://www.sierrachart.com/image.php?l=1397669950744.png After - http://www.sierrachart.com/image.php?l=1397669985739.png Thanks |
[2014-04-16 17:50:06] |
You could try using the Error Filter: https://www.sierrachart.com/index.php?l=doc/doc_ErrorFilter.html This might be hard to filter out those price spikes because they are not very far off from the current price. You could end up filtering out good data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
