Date/Time: Sat, 04 May 2024 04:31:06 +0000
Dot on Chart Instead of Colored Background
View Count: 1158
[2014-04-16 17:39:04] |
User16114 - Posts: 153 |
I am using "=AND(ID13.SG3<ID14.SG3" in "Color Background Based On Alert Condition" study for a Buy condition with green background, as well as the opposite for a Sell condition with a red background. Sometimes both alert conditions are met on the same bar but only one background color can be visible on the chart. Is there away to use the alert condition above, but put a green dot under the bar for the buy alert instead of a colored background? And a red dot above the bar for a triggered sell alert. Thanks! |
[2014-04-16 18:15:13] |
Yes. This can be done with the Color Bar Based on Alert Condition study. You just need to use the Point on High or Point on Low Draw Styles.
[2014-04-16 18:41:19] |
I know you don't like thank you notes clogging the support board but I spent a long time trying to find this solution and can't resist a THANK YOU! This is really awesome software! |
