Date/Time: Thu, 02 May 2024 17:05:51 +0000
10 year note
View Count: 988
[2014-04-16 17:36:10] |
User28682 - Posts: 233 |
Is $TNX the correct symbol for the 10 year note? I get symbol not found in a chart.I looked in up in SC "find symbol" -> "index". Thanks Tom |
[2014-04-16 17:39:20] |
You need to update Sierra Chart to the latest version. Here are the instructions: https://www.sierrachart.com/index.php?l=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-16 18:07:02] |
Thanks, I did download the latest version...I still get symbol not found for $TNX for the 10 year...do I need a different exchange to get this? Thanks Tom |
[2014-04-16 18:10:15] |
You will need to activate the CBOE exchange: https://www.sierrachart.com/usercp.php?page=MarketDataFeedFeatures Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
