Date/Time: Sun, 19 May 2024 21:31:18 +0000
Error creating the primary FXCM Trading service API object. The
View Count: 2156
[2013-04-25 13:27:34] |
yoytu - Posts: 59 |
so where is the api client ? i dont get any url on the log from where to download the api
[2013-04-25 17:35:57] |
Please follow through the instructions here to use FXCM FIX instead: http://www.sierrachart.com/index.php?l=doc/FXCMTrading.php#Setup We are only supporting FIX at this time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-26 04:21:04] |
bfalk - Posts: 33 |
Any plans on adding support for the API? FXCM doesn't want to give me FIX without $25k, which is a bit more than I'm comfortable with in a trading account at this stage. -Brandon |
[2013-04-26 04:22:24] |
We were not aware of this. We will check with them on this.
[2013-04-29 21:00:57] |
We have contacted FXCM about this. They will allow an FIX connection for your account. We have given them your contact information so they should be following up with you.
[2013-04-30 18:43:12] |
Brandon, We have sent you an email in regards to this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
