Date/Time: Tue, 07 May 2024 13:42:29 +0000
FXCM Normal Account
View Count: 875
[2014-04-16 15:30:22] |
selva123 - Posts: 3 |
Dear Customer support, If I have a normal FXCM live account will i be able to log into FXCM FIX data service for me to use Number Bars? Thanks, Selva |
[2014-04-16 16:55:12] |
If you just want to use Numbers Bars with FXCM data, use this service: https://www.sierrachart.com/index.php?l=doc/SCRealTimeFOREX.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
