Date/Time: Sun, 19 May 2024 00:03:36 +0000
Disappearing Charts
View Count: 1051
[2014-04-16 15:15:30] |
Richard Reyes - Posts: 98 |
I have anywhere from 3 to 6 currency pair charts running at one time. Suddenly my charts are disappearing and I am left with a blank screen. This has now happened twice and no matter what I do, they are still blank. This has occurred over the past couple of days. Please advise.
[2014-04-16 16:53:42] |
We need to understand this better. So when you look at a particular chart are you saying it is completely blank?
[2014-04-16 17:27:44] |
The screen is not blank just the chart area. I can still see all supporting boxes, but where the specific currency pair chart should be, there is nothing.
[2014-04-16 17:37:23] |
Remove all studies from the chart to make sure one of those is not causing the problem. And refer to this help topic: https://www.sierrachart.com/index.php?l=doc/helpdetails7.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-18 14:57:44] |
I have automated trading disabled and I have removed the studies that I do have one by one and the chart is still blank. As of this writing, one more chart has disappeared. I have updated the current version of Sierra Charts and I have "Deleted All Data and Downloaded" and still 3 blank charts. At this rate, all my charts will soon be blank. Please advise.
[2014-04-18 20:29:05] |
Go to one of the charts and make sure the Chart Settings which can affect this are set correctly. Refer to: https://www.sierrachart.com/index.php?l=doc/helpdetails7.html#h7.3 If you still in the problem, restart Sierra Chart again, open just one chart and then provide a copy of the Message Log, by following these instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-18 22:44:14] |
Software version: 1115 | 2014-04-18 09:46:33 Usage end date: 2014-09-03 | 2014-04-18 09:46:33 Enabled for: Sierra Chart Historical Data Service. | 2014-04-18 09:46:33 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-04-18 09:46:33 Active service: SC Forex Data (FXCM) | 2014-04-18 09:46:33 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-04-18 09:46:33 2014-04-18 09:46:33 Local computer clock time | 2014-04-18 09:46:33 2014-04-18 14:46:33 GMT time | 2014-04-18 09:46:33 2014-04-18 09:46:33 Time zone adjusted time | 2014-04-18 09:46:33 Time difference to server time: 2 seconds. | 2014-04-18 09:46:33 Program path: H:\SierraChart\ | 2014-04-18 09:46:33 Data Files path: H:\SierraChart\Data\ | 2014-04-18 09:46:33 OS Version Number: 6.1 | 2014-04-18 09:46:33 Checking for new symbol settings for scfxcm | 2014-04-18 09:46:33 Symbol settings are up-to-date for scfxcm | 2014-04-18 09:46:34 SC Forex Data (FXCM): Connecting to the server ds3.sierracharts.com. Port 443 | 2014-04-18 09:46:38 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-04-18 09:46:38 The network socket is connected. | 2014-04-18 09:46:39 SC Forex Data (FXCM): Connected to server. | 2014-04-18 09:46:39 SC Forex Data (FXCM): Sending logon request message. | 2014-04-18 09:46:39 SC Forex Data (FXCM) Server Info - Server Name: . Server Version: . Provider Name: . | 2014-04-18 09:46:39 SC Forex Data (FXCM) - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-04-18 09:46:39 SC Forex Data (FXCM) - Successfully connected. | 2014-04-18 09:46:39 Error creating Intraday data file: H:\SierraChart\Data\EURJPY.scid | 2014-04-18 09:46:41 Failed to get dates from Intraday data file. Failed to open the file H:\SierraChart\Data\EURJPY.scid for reading. Windows error code 1392: The file or directory is corrupted and unreadable. File: H:\SierraChart\Data\EURJPY.scid | 2014-04-18 09:46:41 Error creating Intraday data file: H:\SierraChart\Data\EURJPY.scid | 2014-04-18 09:46:41 Failed to get dates from Intraday data file. Failed to open the file H:\SierraChart\Data\EURJPY.scid for reading. Windows error code 1392: The file or directory is corrupted and unreadable. File: H:\SierraChart\Data\EURJPY.scid | 2014-04-18 09:46:41 Error opening the file. Windows error code 1392: The file or directory is corrupted and unreadable. H:\SierraChart\Data\EURJPY.scid | 2014-04-18 09:46:41 Error creating Intraday data file: H:\SierraChart\Data\EURJPY.scid | 2014-04-18 09:46:41 Failed to get dates from Intraday data file. Failed to open the file H:\SierraChart\Data\EURJPY.scid for reading. Windows error code 1392: The file or directory is corrupted and unreadable. File: H:\SierraChart\Data\EURJPY.scid | 2014-04-18 09:46:41 Error creating Intraday data file: H:\SierraChart\Data\EURJPY.scid | 2014-04-18 09:46:41 Failed to get dates from Intraday data file. Failed to open the file H:\SierraChart\Data\EURJPY.scid for reading. Windows error code 1392: The file or directory is corrupted and unreadable. File: H:\SierraChart\Data\EURJPY.scid | 2014-04-18 09:46:41 Error opening the file. Windows error code 1392: The file or directory is corrupted and unreadable. H:\SierraChart\Data\EURJPY.scid | 2014-04-18 09:46:41 Error creating Intraday data file: H:\SierraChart\Data\GBPCHF.scid | 2014-04-18 09:46:42 Failed to get dates from Intraday data file. Failed to open the file H:\SierraChart\Data\GBPCHF.scid for reading. Windows error code 1392: The file or directory is corrupted and unreadable. File: H:\SierraChart\Data\GBPCHF.scid | 2014-04-18 09:46:42 Error creating Intraday data file: H:\SierraChart\Data\GBPCHF.scid | 2014-04-18 09:46:42 Failed to get dates from Intraday data file. Failed to open the file H:\SierraChart\Data\GBPCHF.scid for reading. Windows error code 1392: The file or directory is corrupted and unreadable. File: H:\SierraChart\Data\GBPCHF.scid | 2014-04-18 09:46:42 Error opening the file. Windows error code 1392: The file or directory is corrupted and unreadable. H:\SierraChart\Data\GBPCHF.scid | 2014-04-18 09:46:42 Error creating Intraday data file: H:\SierraChart\Data\GBPCHF.scid | 2014-04-18 09:46:42 Failed to get dates from Intraday data file. Failed to open the file H:\SierraChart\Data\GBPCHF.scid for reading. Windows error code 1392: The file or directory is corrupted and unreadable. File: H:\SierraChart\Data\GBPCHF.scid | 2014-04-18 09:46:42 Error creating Intraday data file: H:\SierraChart\Data\GBPCHF.scid | 2014-04-18 09:46:42 Failed to get dates from Intraday data file. Failed to open the file H:\SierraChart\Data\GBPCHF.scid for reading. Windows error code 1392: The file or directory is corrupted and unreadable. File: H:\SierraChart\Data\GBPCHF.scid | 2014-04-18 09:46:42 Error opening the file. Windows error code 1392: The file or directory is corrupted and unreadable. H:\SierraChart\Data\GBPCHF.scid | 2014-04-18 09:46:42 Error opening or reading chart data file. File: H:\SierraChart\Data\EURJPY.scid | 2014-04-18 09:46:43 Error opening or reading chart data file. File: H:\SierraChart\Data\EURJPY.scid | 2014-04-18 09:46:43 Error opening or reading chart data file. File: H:\SierraChart\Data\GBPCHF.scid | 2014-04-18 09:46:43 Error opening or reading chart data file. File: H:\SierraChart\Data\GBPCHF.scid | 2014-04-18 09:46:43 SC Forex Data (FXCM) - Starting real-time market data updates for: EURJPY | 2014-04-18 09:46:43 HD Request # 2 - Downloading Intraday chart data for EURJPY to the file EURJPY.scid. Service: fxcm | 2014-04-18 09:46:43 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:43 HD Request # 2 - Failed to open the file H:\SierraChart\Data\EURJPY.scid. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the Intraday data file for download. | 2014-04-18 09:46:43 HD Request # 2 - Error downloading historical Intraday data for EURJPY. Not downloading any Intraday data for symbol EURJPY. | 2014-04-18 09:46:43 HD Request # 2 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for EURJPY | 2014-04-18 09:46:43 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:43 HD Request # 2 - Error opening Intraday data files to add Time and Sales records. Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:43 HD Request # 2 - Intraday download COMPLETE for EURJPY | 2014-04-18 09:46:43 Real-time Intraday chart data file updates started for EURJPY | 2014-04-18 09:46:43 SC Forex Data (FXCM) - Starting real-time market data updates for: EURUSD | 2014-04-18 09:46:43 HD Request # 3 - Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2014-04-18 09:46:43 HD Request # 3 - Download start Date-Time: 2014-04-17 21:23:14.0 | 2014-04-18 09:46:43 HD Request # 3 - Using server: ds5.sierracharts.com port 10149 | 2014-04-18 09:46:43 SC Forex Data (FXCM) - Starting real-time market data updates for: GBPCHF | 2014-04-18 09:46:43 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-04-18 09:46:43 SC Forex Data (FXCM) - Starting real-time market data updates for: USDMXN | 2014-04-18 09:46:43 The network socket is connected. | 2014-04-18 09:46:43 HD Request # 3 - Sending historical data logon request message. | 2014-04-18 09:46:43 HD Request # 3 - Requesting Intraday data. Max. days to return: 186. Start Date-Time: 2014-04-18 02:23:14. Record interval: 0 | 2014-04-18 09:46:44 HD Request # 3 - Decompressing data. | 2014-04-18 09:46:44 HD Request # 3 - Receiving Intraday data for EURUSD starting at 2014-04-17 21:23:14 | 2014-04-18 09:46:44 HD Request # 3 - Timestamp of first Intraday data file record written: 2014-04-17 21:24:30 | 2014-04-18 09:46:44 Requesting market depth updates for: GBPCHF if supported. | 2014-04-18 09:46:44 Socket has been shutdown and closed. | 2014-04-18 09:46:44 The network socket for historical data has been closed. | 2014-04-18 09:46:44 HD Request # 3 - Received 8273 records from 2014-04-17 21:23:14 to 2014-04-18 09:46:29 (12.4 hours) and wrote 8272 records for EURUSD | 2014-04-18 09:46:44 HD Request # 3 - Intraday download COMPLETE for EURUSD | 2014-04-18 09:46:44 Real-time Intraday chart data file updates started for EURUSD | 2014-04-18 09:46:44 HD Request # 4 - Downloading Intraday chart data for GBPCHF to the file GBPCHF.scid. Service: fxcm | 2014-04-18 09:46:44 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:44 HD Request # 4 - Failed to open the file H:\SierraChart\Data\GBPCHF.scid. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the Intraday data file for download. | 2014-04-18 09:46:44 HD Request # 4 - Error downloading historical Intraday data for GBPCHF. Not downloading any Intraday data for symbol GBPCHF. | 2014-04-18 09:46:44 HD Request # 4 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GBPCHF | 2014-04-18 09:46:44 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:44 HD Request # 4 - Error opening Intraday data files to add Time and Sales records. Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:44 HD Request # 4 - Intraday download COMPLETE for GBPCHF | 2014-04-18 09:46:44 Real-time Intraday chart data file updates started for GBPCHF | 2014-04-18 09:46:44 HD Request # 5 - Downloading Intraday chart data for USDMXN to the file USDMXN.scid. Service: fxcm | 2014-04-18 09:46:44 HD Request # 5 - Download start Date-Time: 2014-04-17 21:09:34.0 | 2014-04-18 09:46:44 HD Request # 5 - Using server: ds4.sierracharts.com port 10149 | 2014-04-18 09:46:44 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-04-18 09:46:44 The network socket is connected. | 2014-04-18 09:46:44 HD Request # 5 - Sending historical data logon request message. | 2014-04-18 09:46:44 HD Request # 5 - Requesting Intraday data. Max. days to return: 186. Start Date-Time: 2014-04-18 02:09:34. Record interval: 0 | 2014-04-18 09:46:45 HD Request # 5 - Decompressing data. | 2014-04-18 09:46:45 HD Request # 5 - Receiving Intraday data for USDMXN starting at 2014-04-17 21:09:34 | 2014-04-18 09:46:45 HD Request # 5 - Timestamp of first Intraday data file record written: 2014-04-17 21:44:15 | 2014-04-18 09:46:45 Socket has been shutdown and closed. | 2014-04-18 09:46:46 The network socket for historical data has been closed. | 2014-04-18 09:46:46 HD Request # 5 - Received 3638 records from 2014-04-17 21:09:34 to 2014-04-18 09:46:29 (12.6 hours) and wrote 3636 records for USDMXN | 2014-04-18 09:46:46 HD Request # 5 - Intraday download COMPLETE for USDMXN | 2014-04-18 09:46:46 Real-time Intraday chart data file updates started for USDMXN | 2014-04-18 09:46:46 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:49 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:46:49 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:49 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:46:49 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:49 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:46:49 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:52 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:46:52 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:53 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:46:53 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:53 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:46:53 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:53 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:46:53 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:53 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:46:53 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:53 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:46:53 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:53 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:46:53 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:53 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:46:53 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:53 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:46:53 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:53 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:46:53 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:53 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:46:53 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:53 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:46:53 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:53 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:46:53 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:46:54 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:46:54 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:47:02 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:47:02 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:47:03 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:47:03 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:47:04 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:47:04 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:47:12 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:47:12 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:47:28 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:47:28 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:47:33 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:47:33 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:47:33 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:47:33 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:47:33 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:47:33 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:47:39 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:47:39 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:47:40 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:47:40 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:47:41 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:47:41 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:48:01 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:48:01 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:48:06 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:48:07 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:48:11 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:48:11 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:48:14 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:48:14 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:48:14 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:48:14 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:48:19 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:48:19 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:48:25 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:48:25 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:48:25 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:48:25 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:48:25 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:48:25 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:48:25 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:48:25 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:48:30 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:48:30 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:48:31 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:48:31 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:48:31 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:48:31 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:48:36 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:48:36 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:48:36 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:48:36 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:48:37 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:48:37 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:48:41 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:48:41 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:48:42 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:48:42 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:48:43 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:48:43 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:48:44 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:48:44 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:48:54 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:48:54 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:01 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:49:01 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:09 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:49:09 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:26 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:49:26 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:28 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:49:28 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:28 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:49:28 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:28 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:49:28 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:28 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:49:28 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:28 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:49:28 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:32 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:49:32 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:32 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:49:32 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:32 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:49:32 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:32 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:49:32 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:32 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:49:32 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:41 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:49:41 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:48 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:49:48 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:52 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:49:52 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:57 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:49:57 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:57 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:49:57 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:57 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:49:57 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:57 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:49:57 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:57 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:49:57 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:57 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:49:57 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:57 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:49:57 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:49:59 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:49:59 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:01 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:01 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:01 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:01 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:02 Failed to open the file H:\SierraChart\Data\GBPCHF.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for GBPCHF. | 2014-04-18 09:50:02 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:06 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:06 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:07 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:07 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:07 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:07 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:07 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:07 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:07 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:07 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:07 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:07 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:07 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:07 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:07 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:07 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:07 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:07 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:08 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:08 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:08 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:08 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:08 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:08 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:08 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:08 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:08 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:08 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:08 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:08 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:09 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:09 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:11 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:11 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:11 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:11 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:11 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:11 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:13 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:13 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:17 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:17 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:18 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:18 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:18 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:18 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:18 Failed to open the file H:\SierraChart\Data\EURJPY.scid for adding records. Windows error code 1392: The file or directory is corrupted and unreadable. Failed to open the intraday data file for EURJPY. | 2014-04-18 09:50:18 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:19 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:19 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:23 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:23 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:24 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:25 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:25 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:30 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:30 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:30 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:30 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:30 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:30 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:30 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:30 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:30 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:31 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:31 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:31 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:31 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:36 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:36 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:36 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:36 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:36 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:36 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:37 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:37 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:39 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:40 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:40 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:40 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:40 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:40 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:41 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:42 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:42 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:43 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:43 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:51 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:51 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:55 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:55 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:55 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:55 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:55 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:55 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:55 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:55 Error getting file attributes for H:\SierraChart\Data\GBPCHF.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:55 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:50:57 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:51:02 Error getting file attributes for H:\SierraChart\Data\EURJPY.scid. Unable to check read-only status. Windows error code 1392: The file or directory is corrupted and unreadable. | 2014-04-18 09:51:03 Error getting file attributes for H:\Si |
[2014-04-18 23:18:45] |
You have got some kind of hardware problem on your system with the H drive: Failed to get dates from Intraday data file. Failed to open the file H:\SierraChart\Data\GBPCHF.scid for reading. Windows error code 1392: The file or directory is corrupted and unreadable. File: H:\SierraChart\Data\GBPCHF.scid | 2014-04-18 09:46:42 Either correct the hardware problem on your own, or seek the help of a computer technician in your area for resolution of this problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-18 23:19:22
