Date/Time: Sun, 05 May 2024 13:58:26 +0000
Tick Charts
View Count: 1133
[2014-04-16 13:54:29] |
User96267 - Posts: 43 |
Hello everyone, I'd like to know how I can configure tick charts in Sierra Charts. For example one candlestick includes 80 ticks. How can I get that? Thanks in advance Max |
[2014-04-16 16:50:55] |
This is set through Chart >> Chart Settings. It is explained here: http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#TimePeriodPerBar The Bar Period Type you will need to use is Number of Trades Per Bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-17 11:34:06] |
Thank you. Worked fine!
[2014-04-17 17:09:48] |
User97778 - Posts: 3 |
good day Please advice, I updated the Sierra (version 1120) and now me delay the rendering price comparison candles included (rendering lags by some three seconds), I've probably tried everything to set it and it does not work, so now I turn to you how to set it back to normal .... thanks in advance P.s Martin G Pukanec Date Time Of Last Edit: 2014-04-17 17:35:07
Bez názvu.jpg / V - Attached On 2014-04-17 17:35:03 UTC - Size: 172.04 KB - 374 views |
[2014-04-17 17:39:26] |
Refer to this help topic: https://www.sierrachart.com/index.php?l=doc/helpdetails4.html And most importantly make sure you do not use IB True Real Time Data: https://www.sierrachart.com/index.php?l=doc/IB.php#TrueRealTimeData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-17 17:41:23
