Date/Time: Tue, 03 Nov 2026 00:23:52 +0000
Number Bars Highlight Values Lower/Greater Than
View Count: 1490
[2022-02-21 19:35:52]
Macan93 - Posts: 3
I'm using numberbars and I'd like to highlight the text in the number bars when the ask/bid volume is below certain number, let's say 10. That is to indicate that low volume has accoured at a certain price.
[2022-02-21 20:59:06]
John - SC Support - Posts: 48388
There is not an option for highlighting the text at a specific level, but you can change the color of the text. You would just need to use the Column # Text Coloring Method of Based on Separate Ask Volume Bid Volume - Actual and then set the Column # Actual Volume Compare Thresholds to the values you would need to get the coloring you want.
Refer to the following for a description of this Text Coloring:
Numbers Bars: Text Coloring Based on Separate Ask Volume Bid Volume - Actual
