Date/Time: Fri, 03 May 2024 08:48:34 +0000
TPO Profile - Initial balance
View Count: 1111
[2014-04-16 11:46:47] |
User54685 - Posts: 2 |
Bonjour, Is it possible to widen the vertical line indicating the initial balance in the study TPO profile chart? Regards Christian Hue |
[2014-04-16 23:36:27] |
We have tested this and the width is automatically set. If it is a significant problem for you, we can see how it could be manually set, at least in part. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-17 06:56:59] |
Bonjour, It's not important but only more confortable. If you can do that, can you also add the verical lines for IBR1, IBR2, IBR3 and IBR4? Regards |
