Date/Time: Wed, 01 May 2024 20:02:41 +0000
FESX - historical data range
View Count: 2066
[2014-04-16 10:35:08] |
corbeste - Posts: 74 |
Hi, On downloading FESX intraday historical data, my charts seem to stop at spring 2011. Is it possible to download more data? I see the FESX<contractnum>.scid files are only 1kb in size before 2011. I would like to perform some testing on earlier data, preferably back to 2009. Bund data goes back this far. My data service settings are set for 3000 days of non-tick data, so there should be no problem here. I am using OEC with the Sierra Charts live feed. -corbeste |
[2014-04-16 16:25:11] |
We see there is data back to December 2009. You should be getting it. Open a chart for the December 2009 FESX contract through File >> Find Symbol. Do you get the data? If not, re-download it with Edit >> Delete All Data and Download.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-16 16:26:51
[2014-04-16 16:44:43] |
I tried that, and also manually tried manually deleting all FESX*.scid files from the data directory. I still receive 0 records for older contracts: " The network socket is connected. | 2014-04-16 11:36:02 HD Request # 9 - Sending historical data logon request message. | 2014-04-16 11:36:02 HD Request # 9 - Requesting Intraday data. Start Date-Time: 2010-03-17 00:00:00. Record interval: 0 | 2014-04-16 11:36:02 Socket has been shutdown and closed. | 2014-04-16 11:36:02 The network socket for historical data has been closed. | 2014-04-16 11:36:02 HD Request # 9 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for FESXM0 | 2014-04-16 11:36:02 HD Request # 9 - Intraday download COMPLETE for FESXM0 | 2014-04-16 11:36:02 Real-time Intraday chart data file updates started for FESXM0 | 2014-04-16 11:36:02 " The file size of FESXM0 is 1kb, like before. This is on attempting to load a intraday FESX chart with 2000 days history. I have send the log file if you need to look at it on program startup (after manually deleting the files), subject is the same as this thread. There is quite a lot of noise in the log as its also loading my ES setup. I can do this with a clean chartbook if required. |
[2014-04-17 08:49:02] |
We have looked into this. Unfortunately, for that particular market there is no historical data earlier than June 2011.
[2014-04-17 08:53:51] |
Do you plan on adding more? A 3 year range is not particularly long for a major stock index - its very hard to to any real testing on that, given the market has been in a steady uptrend over that period.
[2014-04-17 09:12:19] |
We can add 1 year more.
[2014-04-17 10:29:39] |
Ok thanks, the more the merrier as far as I am concerned :)
