Date/Time: Tue, 14 May 2024 01:03:39 +0000
manage chart drawings
View Count: 1032
[2013-04-25 12:35:54] |
Jim - Posts: 31 |
Is there a way to show the date along side the time in the drawing type section. I plan on drawing a bunch of vertical lines and would like to see the dates listed as well. Thanks.
[2013-04-25 13:22:52] |
M5amhan - Posts: 468 |
when you draw the line right click it and go to chart drawing properties>labels>check date
Date Time Of Last Edit: 2013-04-25 13:23:02
[2013-04-25 13:46:06] |
Jim - Posts: 31 |
that i know but how do i get the date to reflect along side the manage chart drawings window
[2013-04-25 17:09:50] |
We will add this.
[2016-11-29 18:12:49] |
distilledmatt - Posts: 10 |
Could you add this to horizontal lines/rays etc? It would be very nice to know what date a line drawn came from in certain circumstances.
[2016-11-29 18:26:16] |
The date is already displayed for all chart drawings for each anchor including horizontal lines. We have no idea why this is being requested when it is so clearly there. This thread is also years old. And also the proper way to make a request is to restate fully what it is you are asking about rather than making reference to prior old posts which we will not necessarily read. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
