Date/Time: Sat, 31 Oct 2026 20:12:17 +0000
Futures Trading Account
View Count: 829
[2022-02-19 14:11:48]
User192201 - Posts: 19
I saw some order routing/execution services offer blurb on startup of the application. Does this mean if I took this feature with SC then I don't need to maintain a trading account with a futures broker and does it mean I don't have to do the monthly dance of disconnecting from SC Data Services and login into CQG etc to validated the real time data and price?
If so how I do sign up?
Thank you,
Raja
[2022-02-19 17:27:02]
No it would not avoid that. However, we definitely do recommend that you get set up with the Teton Order Routing Service instead of CQG:
And you only need an account for 100 USD. Refer to:
Easy Solution to CME Funded Trading Account Requirement
Date Time Of Last Edit: 2022-02-19 17:27:16
