Date/Time: Wed, 01 May 2024 18:54:28 +0000
Need FDAX tickdata from CTS-T4 2013
View Count: 1018
[2014-04-16 03:51:40] |
sbsierra - Posts: 71 |
Hi, I am looking for SCID files from CTS-T4 of FDAX incl. bid/ask data for all contracts of 2013. I will share my trading ideas and DLL for somebody who can give me the files. I am a CTS-T4 customer but only have the mentioned data till Dec 2013. I need it for backtesting. Maybe IQFEED will also work. SCFeed Data is different with bid/ask, so I can not use it for my backtest. Thx, SB |
[2014-04-16 04:07:34] |
You may already be aware that when you are using the newer versions of Sierra Chart, expired futures contracts when using CTS T4 are downloaded from the Sierra Chart Historical Data service. So you can get data back to 2013 for EUREX. You need to follow the instructions in help topic 42.2 here: https://www.sierrachart.com/index.php?l=doc/helpdetails42.html#h42.2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-16 04:13:02
[2014-04-16 06:10:16] |
ariknoi - Posts: 31 |
you can email me arik.noi@gmail.com
[2014-04-17 06:01:26] |
I copied a old contracts from a previous backup to the new instance and changed the name to the new naming convention. I did not use Sierra Chart Historical Data service because of hugh difference in bid/ask data.
[2014-04-17 06:01:43] |
@ariknoi: Just sent you a mail.
