Date/Time: Sun, 01 Nov 2026 22:53:47 +0000
New Instance Stuck at 2 Days ago
View Count: 736
[2022-02-16 13:03:08]
Marlin46 - Posts: 34
After getting updated with Teton and current data I open a New Instance only to find it is stuck and not updating data at all. The data is not flowing as with the original instance. Please help. thanks for any solutions.
[2022-02-16 14:20:16]
Most likely you just need to translate the symbols in the Chartbooks. Use this Edit menu command:
Edit Menu: Edit >> Translate Symbols To Current Service
