Date/Time: Sun, 01 Nov 2026 22:55:22 +0000
charges question
View Count: 807
| [2022-02-16 09:40:41] |
| Marlin46 - Posts: 34 |
I was paying 70 for 3 months and then added the 27 for data equalling 97 for 3 months. when I left transact I had to add the CBOT CME at 3.5 USD (whatever that means) etc to get live data. Is that an extra charge above the extra 27? Not sure I understand all of it completely. Please expain if these are separate issues. thanks. Is this 2 different data feeds? |
| [2022-02-16 09:58:52] |
The pricing of the service packages is here: Description of Service Packages and Pricing: Multiple Month Purchase Discount You are using service package 10. And then there is also the exchange fees which are explained here: Denali Exchange Data Feed: Supported Exchanges (Exchange Fees) These are paid month to month and are in addition to the service package. Just pick the exchanges, that you require and nothing more. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-16 09:59:01
