Date/Time: Tue, 30 Apr 2024 16:28:07 +0000
Data - tick by tick
View Count: 1042
[2014-04-15 12:13:25] |
Sam33 - Posts: 12 |
Hello together, I need help from you. I want to use numbers bars and volume profile. For this kind of trading I need data - tick by tick. Now, I have package 5. Could you tell me, if I need something else or package 5 is enough? For example datafeed? Which setting I need to do? Thank you very much Samuel |
[2014-04-15 16:52:37] |
For what markets do need data for? Do you need real-time data? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-15 17:19:48] |
Sam33 - Posts: 12 |
I need only historical data tick by tick for American indexes: - e-mini S&P 500, - e-mini Nasdaq, - e-mini Russell 2000, - e-mini Dow Jones and - EMD (futures). |
[2014-04-15 17:42:50] |
If you only need historical data, then you just need to use the Sierra Chart Historical Data service which is included with package 5: https://www.sierrachart.com/index.php?l=doc/SierraChartHistoricalData.html This is all you need and all of these markets are provided by that service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-29 01:38:20] |
User761234 - Posts: 15 |
Hey guys, I'm actually looking for a similar thing but for me is important to use tick by tick data. Could you help me please on how to export tick by tick data?
[2023-08-29 14:17:21] |
John - SC Support - Posts: 31213 |
The historical data from Sierra Chart is mostly tick data. For instance, for the CME Group, the tick data goes back to 2011, but you can get data back to 2008 in 1 minute increments between 2008 and 2011. Refer to the information at the following link: Sierra Chart Historical Data Service: What is Included This historical tick data is available with any Sierra Chart package. If you want to export the data, then refer to the following: Exporting and Importing Intraday Data Files: Export and Edit For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-29 16:27:26] |
Great! How can I download the tick by tick since 2011? I believe s&p500 is included in the available data, correct me if I'm wrong. Thank you
[2023-08-29 17:17:10] |
All of our historical data is available with any package. Refer to the following for how to load additional historical data into a chart: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
