Date/Time: Sun, 01 Nov 2026 22:55:15 +0000
Chart setting 0-0-1 - does not display new bars regularly
View Count: 858
[2022-02-15 18:05:53]
User301688 - Posts: 3
Hi Sierra,
I'm facing the problem with the one-second chart interval (0-0-1). I'm using the Interactive brokers (ES-202203-GLOBEX 1 Sec) and I want to use them for scalp trading. But the new bars are not filled with each second (0-0-1), but sometimes after 5 seconds, sometimes after 3 seconds, and sometimes after 10. How I can solve it?
Thank you
[2022-02-15 18:30:06]
The only solution we can give is to use our Denali Exchange Data Feed with the NASDAQ TotalView exchange. Refer to the information here:
How to Use New NASDAQ Total View Data Feed
[2022-02-15 19:13:46]
You definitely do need to use the Denali Data Feed, but you need to activate the CME exchange and not the NASDAQ exchange. And there is not trading necessarily every second no matter what data feed is being used.
Documentation for the Denali Data Feed:
Date Time Of Last Edit: 2022-02-15 19:14:12
