Date/Time: Sun, 01 Nov 2026 22:54:37 +0000
Instance not showing full time
View Count: 810
[2022-02-15 15:13:18]
User946129 - Posts: 15
I realize this is not the place for technical support, but I just cannot find the answer to this problem in any of the threads. Can you kindly tell me why I'm not seeing the full intraday trading in the new instance (see attached)? The original source chart is showing the full time just fine (see 2nd attachment).
Thank you,
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=61426
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=61427
[2022-02-15 16:16:00]
Check your Session Times. Refer to the following:
Chart Session Times
[2022-02-15 17:30:46]
Please see the attached. Session times in settings and chart are not matching, hence my confusion.
Kindly advise,
Thank you,
A.S.
imageNew Instance_2.PNG / V - Attached On 2022-02-15 17:30:41 UTC - Size: 153.63 KB - 200 views
[2022-02-15 18:11:02]
Just enable the option for "Evening Session" and you will then have the full 24 hours. Check this against the way your other chart is setup that is working for you, as you could also just change the End Time of the main session to cover all the hours if you want.
[2022-02-15 22:09:07]
Gotcha, thank you very much!
