Date/Time: Fri, 16 Oct 2026 14:21:06 +0000
How to modify the size of the font for the chart calculator labels?
View Count: 1065
[2022-02-15 11:30:06]
Peter Beil - Posts: 19
How to modify the size of the font for the chart calculator labels? None of the global fonts settings seem to control this.
[2022-02-15 12:24:10]
User907968 - Posts: 885
https://www.sierrachart.com/index.php?page=doc/Tools.html#ChangingTheFontSizeForTextDisplayedWithToolDrawings%20
[2022-02-15 13:01:30]
Thank you! Herere we go: To adjust the size and other properties of Text that is displayed with Tool drawings, select Global Settings >> Tool Settings on the menu. Modify the Global Chart Drawing Font by pressing the Select button within that frame
