Date/Time: Sun, 01 Nov 2026 13:46:13 +0000
Drawing Volume Profile Cannot be edited.
View Count: 792
| [2022-02-14 15:12:23] |
| User547290 - Posts: 87 |
I looked on your site and someone had left a comment that the Volume Profile cannot be edited or adjusted. I have the same issue after the new update of the software so I'm guessing there is a bug issue. I have uploaded a chartbook with the profile attached to on of the charts. If you fix it great, would really be helpful. https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=61350 |
| [2022-02-14 18:20:34] |
| John - SC Support - Posts: 48377 |
We are not having any issue selecting the drawn volume profile in your chart, so we are not seeing any bug. Check the following setting and we recommend setting it to No in order to make selecting the Volume Profile easier: Chart Drawing Tools: Select Drawn Volume Profile by Outline Only (Global Settings >> Tool Settings >> General >> Volume Profiles) But, even with it set to Yes, we can still edit the profile, we just have to select the edge first. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
